Next: Modified Commands
Up: Highlights of What's New
Previous: Improvements and Bug Fixes
- Added semaphores command to provide better semaphore functionality.
Previously, one could use the semaphore_file entry on the run_setup
command to cause elegant to create a file when the run terminated successfully.
The semaphores command improves on this, allowing specification of files
that mark the start and finish of a run. The semaphore_file entry on the run_setup
command is still functional.
Michael Borland
2002-09-02
