Next: Changes to Related Programs
Up: Highlights of What's New
Previous: Improvements to Elements
- amplification_factors
- Now sets all correctors to zero before computing a new amplification factor.
- Output now includes kick amplification function for each
actuator as well as useful parameters in all the output files.
- Added amplification factor output for slopes.
- bunched_beam: Previous versions did not generate
longitudinal phase space for dynamic aperture beam type. This version
does.
- Several improvements where made to orbit correction and closed orbit
computation:
- The orbit correction matrix is now computing using the average
Twiss parameters at the entrance and exit of the elements. The previous
version used just the exit parameters.
- BPM-weighted correction works properly now. In past versions, the
weight was basically either 0 (exclude) or 1 (include).
- Added output of the orbit slopes to the closed orbit output file.
- The fixed-path-length orbit computation algorithm now has improved
convergence.
- Pre-correction corrector zeroing now includes objects other than HKICK, VKICK,
and KICKER.
- error_element:
- Added bind_across_names parameter, which permits
giving the same error to many elements that match a wild-card pattern but have different
names. In previous versions, error binding only applied to elements with the same name.
- Previously, the "plus_or_minus" error type was also necessarily and
by default a fractional error. This is no longer the case. One
must explicitly ask for fractional mode, just as with other error
types.
- find_aperture: Added search_output parameter, which gives a filename
to which details on each tracked particle will be written.
- load_parameters
- Now correctly handles loading and saving parameters when element division is used.
- Optimization
- Added two new optimization methods: ``randomwalk'' and ``randomsample''.
These are very useful when starting from scratch with a system that is, for example,
unstable.
- Added bestOptimizationFunction parameter to final output file. This
gives the best value of the optimization function obtained so far.
- Chromaticity correction is now optionally performed while doing an optimization.
(One can also include the chromaticity in the optimization literally, of course.)
- Added the ability to automatically change the weights of different optimization
function terms to emphasize the most difficult terms. Paradoxically, this can often
result in convergence for all terms.
- Added controls for adjustment of initial simplex size on restart of simplex
optimization.
- Higher-order dispersion and chromaticities are now available for optimization expressions.
- sdds_beam:
- Fixed bug in the code that checks units for elegant-style input
files. In previous versions, if the units of p were blank (an allowed
``error''), other units errors were ignored.
- Now read
data for spiffe input files. (spiffe is
a particle-in-cell code for rf gun simulation, available from the OAG web site.)
- track: Fixed bug that prevented linear chromatic matrix tracking (LCMT) from
working in some cases. LCMT now uses higher-order chromaticity and dispersion, if these
are computed. Also, now uses second-order momentum compaction for longitudinal motion.
- tune_shift_with_amplitude:
- Added controls for adjustment of the initial particle amplitude.
- Fixed problems with computation in presence of MALIGN elements with ON_PASS parameters
not equal to -1.
Robert Soliday
2003-10-17
