Next: Other New Features and
Up: Highlights of What's New
Previous: Modified Commands and Bug
- The program ibsEmittance now provides IBS scattering rate contributions
as a function of position in the ring.
- The program madto now attempts to output COSY format. Users should
check the results carefully!
- The program sddsanalyzebeam now copies input parameters through to output columns.
It also has a new option, -correctedOnly, which results in computation of only
the dispersion-corrected twiss parameters.
- Added the program sddsrandmult, which computes random error multipole
levels for specified quadrupole and sextupole construction errors. The output
of sddsrandmult is accepted by the KQUAD and KSEXT elements.
Robert Soliday
2003-10-17
