Next: correction_matrix_output
Up: Namelist Command Dictionary
Previous: closed_orbit
- type: setup command.
- function: set up for correction of the trajectory or closed orbit.
&correct
STRING mode = "trajectory";
STRING method = "global";
STRING trajectory_output = NULL;
STRING corrector_output = NULL;
STRING statistics = NULL;
double corrector_tweek[2] = {1e-3, 1e-3};
double corrector_limit[2] = {0, 0};
double correction_fraction[2] = {1, 1};
double correction_accuracy[2] = {1e-6, 1e-6};
double bpm_noise[2] = {0, 0};
double bpm_noise_cutoff[2] = {1.0, 1.0};
STRING bpm_noise_distribution[2] = {"uniform", "uniform"};
long verbose = 1;
long fixed_length = 0;
long fixed_length_matrix = 0;
long n_xy_cycles = 1;
long n_iterations = 1;
long prezero_correctors = 1;
long track_before_and_after = 0;
long start_from_centroid = 1;
long use_actual_beam = 0;
double closed_orbit_accuracy = 1e-12;
long closed_orbit_iterations = 10;
double closed_orbit_iteration_fraction = 1;
long use_perturbed_matrix = 0;
&end
mode -- Either ``trajectory'' or ``orbit'', indicating
correction of a trajectory or a closed orbit.
method -- For trajectories, may be ``one-to-one'' or
``global''. For closed orbit, must be ``global''.
trajectory_output -- The (incomplete) name of an SDDS file to which the trajectories or orbits will be written. Recommended value: ``%s.traj'' or ``%s.orb''.
corrector_output -- The (incomplete) name of an SDDS file to which information about the final corrector strengths will be written. Recommended value: ``%s.cor''.
statistics -- The (incomplete) name of an SDDS file to which statistical information about the
trajectories (or orbits) and corrector strengths will be written. Recommended value: ``%s.scor''.
corrector_tweek[2] -- The amount by which to change the correctors in order to compute correction coefficients.
[The word ``tweak'' is misspelled ``tweek'' in the code.]
corrector_limit[2] -- The maximum strength allowed for a corrector.
correction_fraction[2] -- The fraction of the computed correction strength to actually use for any one iteration.
correction_accuracy[2] -- The desired accuracy of the correction in terms of the RMS BPM values.
bpm_noise[2] -- The BPM noise level.
bpm_noise_cutoff[2] -- Cutoff values for the random distributions of BPM noise.
bpm_noise_distribution[2] -- May be either ``gaussian'', ``uniform'', or ``plus_or_minus''.
verbose -- If non-zero, information about the correction is printed during computations.
fixed_length -- Indicates that the closed orbit length should be kept the same as the design orbit
length by changing the momentum offset of the beam.
fixed_length_matrix -- Indicates that for fixed-length orbit correction, the fixed-length
matrix should be computed and used. This will improve convergence but isn't always needed.
n_xy_cycles -- Number of times to alternate between correcting the x and y planes.
n_iterations -- Number of iterations of the correction for each x/y cycle.
prezero_correctors -- Flag indicating whether to set the correctors to zero before starting.
track_before_and_after -- Flag indicating whether tracking should be done both before and after
correction.
start_from_centroid -- Flag indicating that correction
should start from the beam centroid. For orbit correction, only the
beam momentum centroid is relevant.
use_actual_beam -- Flag indicating that correction
should employ tracking of the beam distribution rather than a single
particle. This is valid for trajectory correction only.
closed_orbit_accuracy -- Accuracy of closed orbit computation.
closed_orbit_iterations -- Number of iterations of closed orbit computation.
closed_orbit_iteration_fraction -- Fraction of change in closed orbit to
use at each iteration.
use_perturbed_matrix -- If nonzero, specifies that prior to each
correction elegant shall recompute the response matrix. This
is useful if the lattice is changing significantly between corrections.
Robert Soliday
2004-04-21
