&correction_matrix_output
    STRING response[2] = NULL, NULL;
    STRING inverse[2] = NULL, NULL;
    long KnL_units = 0;
    long BnL_units = 0;
    long output_at_each_step = 0;
    long output_before_tune_correction = 0;
    long fixed_length = 0;
&end
response -- Array of (incomplete) filenames for SDDS output of the x and y response
matrices.  Recommnended values: ``inverse -- Array of (incomplete) filenames for SDDS output of the x and y
inverse response matrices. Recommnended values: ``KnL_units -- Flag that, if set, indicates use of ``units'' of m/K0L rather than
m/rad.  This results in a sign change for the horizontal data.
BnL_units -- Flag that, if set, indicates use of ``units'' of m/(T*m) rather than
m/rad.  This is useful for linac work in that the responses are automatically scaled with
beam momentum.
output_at_each_step -- Flag that, if set, specifies output of the data at
each simulation step.  By default, the data is output immediately for the defined lattice.
output_before_tune_correction -- Flag that, if set, specifies that when
output_at_each_step is set, that output shall occur prior to correcting the tunes.
fixed_length -- Flag that, if set, specifies output of the fixed-path-length
matrix.
