Next: tune_shift_with_amplitude
Up: Namelist Command Dictionary
Previous: twiss_output
- type: action command.
- function: track particles.
&track
long center_on_orbit = 0;
long center_momentum_also = 1;
long offset_by_orbit = 0;
long offset_momentum_also = 1;
long soft_failure = 1;
long use_linear_chromatic_matrix = 0;
long longitudinal_ring_only = 0;
&end
center_on_orbit -- A flag indicating whether to center
the beam transverse coordinates on the closed orbit before tracking.
center_momentum_also -- A flag indicating whether to
center the momentum coordinate also.
offset_by_orbit -- A flag indicating whether to offset
the transverse beam coordinates by the closed orbit before tracking.
Similar to center_on_orbit, but the initial centroids of the
beam are preserved. The beam is simply displaced by the closed orbit
rather than being centered on it.
offset_momentum_also -- A flag indicating whether to also
offset the beam momentum to the momentum of the closed orbit. If the
start_from_centroid or start_from_dp_centroid parameters are
used on the closed_orbit command, this flag should be set to
0; otherwise, one will offset the beam central momentum by its own value.
soft_failure -- If there is an error during tracking (e.g.,
a failure of orbit correction), continue to produce file output. This
creates essentially empty slots in the files corresponding to the failed
steps.
use_linear_chromatic_matrix -- For each particle, a first-order
matrix is computed for the particular momentum offset
of the particle using the linear chromaticity and linear dependence of
the beta functions on momentum.
longitudinal_ring_only -- Tracks longitudinal coordinates only
for a ring.
Robert Soliday
2004-04-21
