Next: vary_element
Up: Namelist Command Dictionary
Previous: track
- type: setup command.
- function: prepare for computation of tune shifts with amplitude.
- note: must be given prior to the
twiss_output command.
- method: tune shifts with amplitude are computed via tracking a series of
particles at different amplitudes or by a matrix method. NAFF is used to
determine the tunes
from the tracking data. It is the user's responsbility to optimize the
parameters to ensure that results are reasonable. Using tracking to determine
tune shifts is more accurate than analytical methods as it includes multi-turn
effects that are important in some rings (e.g., the APS).
&tune_shift_with_amplitude
long turns = 2048;
double x0 = 1e-6;
double y0 = 1e-6;
double x1 = 3e-4;
double y1 = 3e-4;
long grid_size = 6;
long sparse_grid = 0;
long spread_only = 0;
double nux_roi_width = 0.02;
double nuy_roi_width = 0.02;
double scale_down_factor = 2;
double scale_up_factor = 1.05;
double scale_down_limit = 0.01;
double scale_up_limit = 1e-4;
long scaling_iterations = 10;
long use_concatenation = 0;
long verbose = 0;
long order = 2;
STRING tune_output = NULL;
&end
turns -- The number of turns to track. If zero, then the concatenated matrix
is used instead of tracking, and all other parameters of this command are irrelevant.
The matrix method doesn't work well with all lattices. The order
of the concatenated matrix is given by the concat_order control in
twiss_output.
x0, y0 -- The initial x and y amplitudes to use for determining the
small-amplitude tunes.
x1, y1 -- The initial x and y amplitudes to user for determining the
tune shifts. These values should be small enough to ensure linearity in the tune
shift.
grid_size -- Size of the grid of points in x and y.
sparse_grid -- If nonzero, then instead of a full set of grid_size
particles, a sparse grid of particles is tracked. Will save time at some expense
in accuracy.
spread_only -- Compute the tune spread only and don't bother with the
tune shift coefficients. These tune spreads can be optimized and appear in the
twiss output file under the names nuxTswaLower, nuxTswaUpper, and
similarly for the y plane. This is the recommended way to reduce tune shift
with amplitude, as the tune spread is more reliable than the coefficients of
the expansion. (Particles that get lost are automatically ignored in both
types of computations.)
nux_roi_width, nuy_roi_width -- Widths of the region of interest for
x and y tunes. As the grid is filled in, elegant finds the tune for each
tracked particle on the grid. Successive tune values are looked for in the
region of the given width around the previous tune value. This prevents jumping
from the main tune peak to another peak, which can happen when the tune spectrum
has many lines.
scale_down_factor, scale_up_factor, scale_down_limit,
scale_up_limit, scaling_iterations -- These control automatic scaling
of the amplitudes. If elegant sees a tune shift larger than scale_down_limit
it will decrease x0 (or y0) by the factor scale_down_factor.
If elegant sees a tune shift smaller than scale_up_limit
it will increase x0 (or y0) by the factor scale_up_factor.
Suggestion: if you find yourself playing with these values and the initial amplitudes
in order to get reliable TSWA coefficients, try just using the tune spread.
verbose -- If nonzero, information about the progress of the algorithm is
printed to the screen.
use_concatenation -- If nonzero, then tracks with the concatenated matrix instead
of element-by-element. The order
twiss_output. The user should experiment with this option to see if the
results are reliable for a particular lattice.
Next: vary_element
Previous: track
Robert Soliday
2004-04-21
