| Parameter Name | Units | Type | Default | Description |
| L | double | 0.0 | length | |
| VOLT | double | 0.0 | peak voltage | |
| PHASE | double | 0.0 | phase | |
| FREQ | double | 500000000 | frequency | |
| Q | double | 0.0 | cavity Q (for cavity that charges up to given voltage from 0) | |
| PHASE_REFERENCE | long | 0 |
phase reference number (to link with other time-dependent elements) | |
| CHANGE_P0 | long | 0 |
does cavity change central momentum? | |
| CHANGE_T | long | 0 |
set to 1 for long runs to avoid rounding error in phase | |
| FIDUCIAL | STRING | NULL | mode for determining fiducial arrival time (light, tmean, first, pmaximum) | |
| END1_FOCUS | long | 0 |
include focusing at entrance? | |
| END2_FOCUS | long | 0 |
include focusing at exit? | |
| BODY_FOCUS_MODEL | STRING | NULL | None (default) or SRS (simplified Rosenzweig/Serafini for standing wave) | |
| N_KICKS | long | 1 | number of kicks to use. Set to zero for matrix method. | |
| DX | double | 0.0 | misalignment | |
| DY | double | 0.0 | misalignment | |
| T_REFERENCE | double | -1 | arrival time of reference particle | |
| LINEARIZE | long | 0 |
Linearize phase dependence? |
The body-focusing model is based on Rosenzweig and Serafini, Phys. Rev. E 49 (2),
1599.  As suggested by N. Towne (NSLS), I simplified this to assume a pure pi-mode
standing wave.
The CHANGE_T parameter may be needed for reasons that stem from
elegant's internal use of the total time-of-flight as the
longitudinal coordinate.  If the accelerator is very long or a large
number of turns are being tracked, rounding error may affect the
simulation, introducing spurious phase jumps.  By setting
CHANGE_T=1, you can force elegant to modify the time
coordinates of the particles to subtract off
, where
 is the rf period and
.  If
you are tracking a ring with rf at some harmonic
 of the revolution
frequency, this will result in the time coordinates being relative to
the ideal revolution period,
.  If you have multiple rf
cavities in a ring, you need only use this feature on one of them.
Also, you can use CHANGE_T=1 if you simply prefer to have the
offset time coordinates in output files and analysis.
N.B.: Do not use CHANGE_T=1 if you have rf cavities that
are not at harmonics of one another or if you have other
time-dependent elements that are not resonant.
