| Parameter Name | Units | Type | Default | Description |
| L | double | 0.0 | length | |
| CELL_LENGTH | double | 0.0 | cell length (used to scale wakes, which are assumed to be given for a cell) | |
| VOLT | double | 0.0 | voltage | |
| PHASE | double | 0.0 | phase | |
| FREQ | double | 500000000 | frequency | |
| Q | double | 0.0 | cavity Q (for cavity that charges up to voltage from 0) | |
| PHASE_REFERENCE | long | 0 |
phase reference number (to link with other time-dependent elements) | |
| CHANGE_P0 | long | 0 |
does element change central momentum? | |
| CHANGE_T | long | 0 |
see RFCA documentation | |
| FIDUCIAL | STRING | NULL | mode for determining fiducial arrival time (light, tmean, first, pmaximum) | |
| END1_FOCUS | long | 0 |
include focusing at entrance? | |
| END2_FOCUS | long | 0 |
include focusing at exit? | |
| BODY_FOCUS_MODEL | STRING | NULL | None (default) or SRS (simplified Rosenzweig/Serafini for standing wave) | |
| N_KICKS | long | 1 | number of kicks to use. Set to zero for matrix method. | |
| WAKEFILE | STRING | NULL | name of file containing Green functions | |
| ZWAKEFILE | STRING | NULL | if WAKEFILE=NULL, optional name of file containing longitudinal Green function | |
| TRWAKEFILE | STRING | NULL | if WAKEFILE=NULL, optional name of file containing transverse Green functions | |
| TCOLUMN | STRING | NULL | column containing time data | |
| WXCOLUMN | STRING | NULL | column containing x Green function |
A combination of RFCA, WAKE, TRWAKE, and LSCDRIFT.
| WYCOLUMN | STRING | NULL | column containing y Green function | |
| WZCOLUMN | STRING | NULL | column containing longitudinal Green function | |
| N_BINS | long | 0 |
number of bins for current histogram | |
| INTERPOLATE | long | 0 |
interpolate wake? | |
| SMOOTHING | long | 0 |
smooth current histogram? | |
| SG_HALFWIDTH | long | 4 | Savitzky-Golay filter half-width for smoothing | |
| SG_ORDER | long | 1 | Savitzky-Golay filter order for smoothing | |
| DX | double | 0.0 | misalignment | |
| DY | double | 0.0 | misalignment | |
| LINEARIZE | long | 0 |
Linearize phase dependence? | |
| LSC | long | 0 |
Include longitudinal space-charge impedance? | |
| LSC_BINS | long | 1025 | Number of bins for LSC calculations | |
| LSC_INTERPOLATE | long | 1 | Interpolate computed LSC wake? | |
| LSC_HIGH_FREQUENCY_CUTOFF0 | double | -1 | Spatial frequency at which smoothing filter begins for LSC. If not positive, no frequency filter smoothing is done. Frequency is in units of Nyquist (0.5/binsize). | |
| LSC_HIGH_FREQUENCY_CUTOFF1 | double | -1 | Spatial frequency at which smoothing filter is 0 for LSC. If not given, defaults to HIGH_FREQUENCY_CUTOFF0. | |
| LSC_RADIUS_FACTOR | double | 1.7 | LSC radius is (Sx+Sy)/2*RADIUS_FACTOR | |
| WAKES_AT_END | long | 0 |
Do wake kicks at end of segment (for backward compatibility)? |
This element is a combination of the RFCA, WAKE, and TRWAKE elements.  As such, it provides combined simulation of an rf
cavity with longitudinal and transverse wakes.
For the wakes, the input files and their interpretation are identical to WAKE and TRWAKE, except that the transverse and longitudinal wakes are interpreted as the wakes for a single cell of length given by the CELL_LENGTH parameter.
Users should read the entries for WAKE, TRWAKE, and RFCA for more details on this element.
