Next: Changes and Additions to
Up: Highlights of What's New
Previous: New and Modified Elements
- Added the
momentum_aperture command, which allows determination of the s-dependent
momentum aperture. This work was inspired by requests from R. Bartolini (DLS) and F. Wang (MIT),
as well as a discussion with L. Nadolski (SOLEIL).
- Added the
aperture_input command, which allows specifying s-dependent aperture using
an SDDS file. This was inspired by a discussion with R. Bartolini (DLS).
- Added computation of the coupling integral and emittance ratio (see section 3.1.4.4 of
[18]). These are available for optimization using the symbols couplingIntegral
and emittanceRatio. N.B.: this emittance ratio does not include the effect of
vertical dispersion. This change was suggested by V. Sajaev (ANL).
- Added computation of coupled twiss parameters and beam sizes,
using code supplied by V. Sajaev (ANL) based on [17]. This
is done with the new
coupled_twiss_output command. The
command requires specifying the emittance ratio. While one might be
tempted to use the value from the coupling integral (as in the
previous item), we again note that this does not include vertical
dispersion contributions.
- Added the
match_name feature to the twiss_analysis
command. For example, one can now compute and optimize on the
average
at elements with names matching a wildcard string.
- The default number of iterations for orbit correction (
correct command)
was increased to improve results for difficult (nearly unstable) cases. On a related note,
if closed orbit computations are requested, they are now additionally performed
prior to orbit correction in case orbit correction needs the perturbed correction matrix.
- Added the
linear_chromatic_tracking_setup command, which allows tracking
with a linear matrix representing a ring with defined chromatic variation of the
tunes and lattice functions. This was previously only possible if the ring lattice
was defined. The new feature allows tracking without defining the ring lattice.
This was requested by S. Krinsky (BNL).
Robert Soliday
2006-05-05
