Next: Introduction
Up: Highlights of What's New
Previous: New and Modified Commands
- The program sddsfindresonances was added. It analyzes frequency map analysis data
to find resonance lines. The program was written by H. Shang (ANL).
- Support for s-dependent momentum aperture computation was added to
elegantRingAnalysis.
This can be done with many processors at once, and is therefore quite fast.
- Most computations in
elegantRingAnalysis now use the second-order concatenated matrix
for better convergence of close orbits. This requires setting the default matrix order to
2 in these runs. This should not impact any results as long as the tracking lattice file uses
kick elements (recommended in any case).
- The program
sddsurgent was added. It performs computations of undulator radiation properties
using code from the programs URGENT (R. Walker) and US (R. Dejus). It was written by H. Shang (ANL).
In addition, a script called quickSDDSUrgent was added that provides a basic graphical interface
to sddsurgent. It was written by X. Jiao (ANL).
- The program
sddsemitproc was changed to improve behavior when invalid results are returned from correction algorithms.
Fixed bug in parsing error settings. Fixed bug in setting output parameters
(S33 not set).
Next: Introduction
Robert Soliday
2006-05-05
