next up previous
Next: RFTM110 Up: Element Dictionary Previous: RFDF
RFMODE
A simulation of a beam-driven TM monopole mode of an RF cavity.
Parallel capable? : yes
Parameter Name Units Type Default Description
RA $Ohm$ double 0.0 shunt impedance
RS $Ohm$ double 0.0 shunt impedance (Ra=2*Rs)
Q   double 0.0 cavity Q
FREQ $Hz$ double 0.0 frequency
CHARGE $C$ double 0.0 beam charge (or use CHARGE element)
INITIAL_V $V$ double 0.0 initial voltage
INITIAL_PHASE $RAD$ double 0.0 initial phase
INITIAL_T $S$ double 0.0 time at which INITIAL_V and INITIAL_PHASE held
BETA   double 0.0 normalized load impedance
BIN_SIZE $S$ double 0.0 bin size for current histogram (use 0 for autosize)
N_BINS   long 20 number of bins for current histogram
PRELOAD   long 0 preload cavity with steady-state field
PRELOAD_FACTOR   double 1 multiply preloaded field by this value
RIGID_UNTIL_PASS   long 0 don't affect the beam until this pass
DETUNED_UNTIL_PASS   long 0 cavity is completely detuned until this pass
SAMPLE_INTERVAL   long 1 passes between output to RECORD file
RECORD   STRING NULL output file for cavity fields
SINGLE_PASS   long 0 if nonzero, don't accumulate field from pass to pass
PASS_INTERVAL   long 1 interval in passes at which to apply PASS_INTERVAL times the field (may increase speed)
FREQ_WAVEFORM   STRING NULL $<$filename$>$=$<$x$>$+$<$y$>$ form specification of input file giving frequency/f0 vs time, where f0 is the frequency given with the FREQ parameter
Q_WAVEFORM   STRING NULL $<$filename$>$=$<$x$>$+$<$y$>$ form specification of input file giving qualityFactor/Q0 vs time, where Q0 is the quality factor given the the Q parameter.
RAMP_PASSES   long 0 Number of passes over which to linearly ramp up the impedance to full strength.
BINLESS   long 0 If nonzero, use algorithm that doesn't requiring binning. Best for few particles, widely spaced.
next up previous
Robert Soliday 2007-04-02
