&insert_sceffects
STRING name = NULL;
STRING type = NULL;
STRING exclude = NULL;
long disable = 0;
long clear = 0;
STRING element_prefix = "MYSC";
long skip = 0;
long vertical = 0;
long horizontal = 0;
long nonlinear = 0;
&end
name -- Possibily wild-card containing string specifying the
elements name. After that, the space charge kick is to be inserted.
type -- Possibily wild-card containing string specifying the
element types. After that, the space charge kick is to be inserted.
exclude -- Possibily wild-card containing string specifying
elements to be excluded from the specified space charge kick insertion.
disable -- If nonzero, the command is ignored.
clear -- If nonzero, all prior space charge insertions are deleted.
element_prefix -- give space-charge kick name. Will apear as element name in beamline.
skip -- If nonzero, number of ``skip'' space charge kicks are skiped.
If zero, only one space charge kick is inserted to the end of beamline.
vertical, horizontal, nonlinear -- Switches for setting up
space charge kick calculation.
