&linear_chromatic_tracking_setup
double nux[4] = {-1, 0, 0, 0};
double betax[2] = {1.0, 0.0};
double alphax[2] = {0.0, 0.0};
double etax[2] = {0.0, 0.0};
double etapx[2] = {0.0, 0.0};
double nuy[4] = {-1, 0, 0, 0};
double betay[2] = {1.0, 0.0};
double alphay[2] = {0.0, 0.0};
double etay[2] = {0.0, 0.0};
double etapy[2] = {0.0, 0.0};
double alphac[2] = {0.0, 0.0};
&end
nux -- Provide the horizontal tune plus its first three chromatic derivatives, i.e.,
betax -- Provide the horizontal beta function plus its chromatic derivative.
alphax -- Provide the horizontal alpha function plus its chromatic derivative.
etax -- Provide the first- and second-order horizontal dispersion:
etapx -- Provide the first- and second-order horizontal dispersion slope.
alphac -- Provide the first and second-order momentum compaction. N.B: if you are tracking
with an rf cavity, be sure that your lattice length equal to the actual circumference. See the example below.
An example of a good lattice for use with this feature is the following:
! Actual length of the ring d0: drift,l=30.6667 ! Actual rf voltage and frequency rf: rfca,l=0,volt=30e3,phase=180,freq="c_mks 30.6667 /" w1: watch,filename="%s.w1",mode="centroid" ring: line=(d0,rf,w1)Any additional elements (e.g,. wakes or impedances) should follow d0. No other elements represented by a matrix should be present!
