Next: Input Files
Up: User's Guide to shower
Previous: Command line
Running shower requires three input files:
- cross-section data: Text data file originating from multiple
PEGS4 runs which provides the physics of the simulation.
- input beam coordinates: SDDS-format file containing initial
coordinates, and energy of the particles. Other parameters, such as
PowerOfInitialBeam, used to calculate absorbed dose rate, may be
defined here.
- geometry definition: File containing namelist type commands defining the
geometry of the problem, i.e. dimensions and material composition.
There are three types of output files:
- output beam coordinates: Coordinates of all particles crossing a
bounding plane of a region defined in the geometry file. The file name
is specified in region definition. The data may be used for
quantitative analysis of a shower, or used as input file to another
run of shower. Particles that go out-of-bounds or entering an
undefined region of space, may be recorded in separate files defined
in the command line.
- shower trajectory: Coordinates of trajectories of all particles
produced in a shower run, including those that are created and
eventually get absorbed.
- summary: Lists quantities related to each region defined, such
as the total energy absorbed.
- line segment geometry: Contains coordinates of all line segments
of the shapes defining the geometry of the problem. Most useful when
overlayed on shower trajectory plots.
Next: Input Files
Robert Soliday
2003-10-17
