Next: Output Files
Up: Input Files
Previous: Input Beam File
The required geometry file is created by the user. Three namelist
commands are available, &initial_coordinates, &block,
and &cylinder. Since the regions can only be of block type or
cylindrical type, the commands &block and &cylinder
can't be mixed in the same geometry file. The fields for the first
command are:
double x_cm = 0.0
double y_cm = 0.0
double z_cm = 0.0
double xp = 0.0
double yp = 0.0
&end
- Defaults are shown on the right hand side of ``=''. The
word ``double'' in the above syntax definition isn't part of the
actual command and should be omitted in a command. It is shown here
only to specify the data ytpe.
- x_cm,y_cm,z_cm -- Amount by which to change the
coordinates of all particles defined in all input files. Units are in
centimeters.
- xp,yp -- Amount by which to change the slope with respect
to the
-axis of all particles defined in all input files.
The &block command defines a block-like region of material:
&block
STRING label = NULL
STRING material = NULL
double x_lower_cm = 0.0
double x_upper_cm = 0.0
double y_lower_cm = 0.0
double y_upper_cm = 0.0
double z_lower_cm = 0.0
double z_upper_cm = 0.0
double Bx = 0.0;
double By = 0.0;
double Bz = 0.0;
double Ex = 0.0;
double Ey = 0.0;
double Ez = 0.0;
long x_slices = 1;
long y_slices = 1;
long z_slices = 1;
STRING outputfile = NULL;
double photonEnergyCutoff = 0.0;
double leptonEnergyCutoff = 0.0;
long split = 1;
double minimumWeight = 0.0;
double maximumDeltaE = 0.02;
&end
- label -- An optional label identifying the region. The
label value will appear in the output file.
- material -- A string specifying the material in the
region. This material can be an element, a mixture, or a compound, and
must be defined in the cross-section file.
The material string value is converted to uppercase and passed
to EGS4 for identification of data arrays in the cross-section data
file defined by environment variable EGS4_CROSSSECTION (see
section 4.1). If this cross-section file exists,
and contains the required information on the specified element,
mixture, or compound, the relevant data is read into EGS4 subroutine
arrays. Otherwise, an error message is printed out, and execution
stops.
In order to track through empty space, the empty space must be defined
as a region of pre-set material ``vacuum''. Otherwise, a
particle entering an undefined region of space will be discarded, and
optionally recorded in a coordinate file (see command line arguments).
- {x,y,z}_lower_cm,{x,y,z}_upper_cm -- Boundaries of the
block region in units of cm (the units used here is to be consistent
with the units used by EGS4). If a later &block definition
overlaps with the volume of one defined earlier, then the first block
takes precedence. Smaller objects such as targets where the shower
process usually starts should be defined first so that they can be
nested inside larger regions.
- Bx,By,Bz -- Uniform magnetic field in entire region. Only
one component of B is allowed in one region. Each tracking segment in
a region with a magnetic field is converted into an arc of a circle
approximated by shorter line segments joined by a small angle, with the
possibility of interaction with matter at each vertex.
- Ex,Ey,Ez -- Electric field in region. Not implemented yet.
- {x,y,z}_slices -- Number of equal divisions of the region
along a particular direction. Each sub-region becomes a new region
with the same label, material, magnetic field. This usually doesn't
affect the Monte Carlo simulation. However, for regions with
dimensions smaller than the mean free path of a particle, the larger
number of steps may improve the simulation of Coulomb scattering.
Also, in the regions summary file each subdivision of a region is considered
as a separate region with the same material and label values. This is a
convenient way to determine absorbed dose as a function of position.
The slice option does not work with the outputfile
specification. Therefore slices should be left equal to 1 if an output
file is specified.
- outputfile -- Creates an ouput file which records
coordinates of particles entering the region. Once in the output
region, the particles are discarded from further tracking. Therefore
the region with the output file is often the ``last'' region of
the geometry.
- photonEnergyCutoff, leptonEnergyCutoff -- Modifies the
energy cut-off of photon and lepton transport for the particular
region. The energy cut-off is defined as the minimum energy at which
the particle can no longer move forward and is absorbed on the spot.
The cut-off energy cannot be made smaller than the default value found
in the cross-section data file. Using a larger value than the default
values may reduce simulation time at the expense of reduced
accuracy. The user must make his own determination.
- split -- When greater than one, allows particle splitting
when particle enters the region, in order to improve statistics for
that region. The number of particles is increased by the value of split. At the same time the weighting of the particles are reduced by
the same factor, thus unaffecting the energy deposited in the region.
- minimumWeight -- Specifies the minimum weighting allowed
when particle splitting is enabled. This prevents a runaway situation
for some geometries where potentially a very large number of particles
are created from a single particle.
- maximumDeltaE -- Specifies the maximum relative energy
loss a particle may suffer when it is tracked through a single
step. This parameter forces the reduction of the path length such that
the relative energy loss is approximately equal to the value given.
The &cylinder command is similar to the &block command:
&cylinder
STRING label = NULL
double r_lower_cm = 0.0
double r_upper_cm = 0.0
double Bx = 0.0
double By = 0.0;
double Bz = 0.0;
double Ex = 0.0;
double Ey = 0.0;
double Ez = 0.0;
long r_slices = 1
long z_slices = 1
long split = 1;
&end
The only difference with the &block command is the absence of
the dimension variables in
, and the replacement of the variables
in
with variables in
. The cylinder defined are concentric and
are centered on the
-axis.
The &block and &cylinder commands can't be mixed in the
same geometry file. If the first material definition command is of one type,
then the rest must be of the same type.
Next: Output Files
Up: Input Files
Robert Soliday
2003-10-17
