&translate
z_trigger = 0.05,
z_lower = 0.02,
z_upper = 0.055
&end
This specifies that when the first particle passes The boundary conditions are changed to Neumann on the upper, right, and left boundaries and Dirichlet on the lower boundary.
&translate
z_lower = <zMin>,
z_upper = <zMax>,
z_trigger = <z0>,
&end
where <zMin> and <zMax> are the minimum and maximum longitudinal
coordinates for the original problem mesh, and <z0> is <zMax>-
