&define_resistor start = 0.02, end = 0.03, position = 0.04, direction = "z", conductivity = 6e3 &endThis specifies a resistor extending in the longitudinal (z) direction from 2cm to 3cm, at a radius of 4cm. The conductivity is
&define_resistor double start = 0; double end = 0; double position = 0; STRING direction = "z"; double conductivity = 1e154; &end
