Next: File Protocol Conversion Tools
Up: SDDS Toolkit Programs by
Previous: Image Processing Tools
  Contents
- elegant2genesis -- Processes particle output from the particle tracking code
elegant[2]
and makes a file suitable for use as the BEAMFILE with the FEL code GENESIS[8].
- sddssampledist -- Draws samples from one or more probability distributions.
Suitable for making input particle distributions for tracking codes, for example,
using user-defined probability distributions.
- sddssequence -- Creates an SDDS data set of arithmetic sequences.
Example application: generating values for an independent variable, whose values can be used by
sddsprocess to produce a mathematical function.
- sddscongen -- Creates an SDDS data set by evaluating an
rpn expression over a defined 2
dimensional grid. Example application: generating values of a function of two variables on a grid for plotting
with sddscontour.
- sddstimeconvert -- Converts time data between seconds-since-epoch and calendar breakdown formats.
Example application: finding the year, month, and day corresponding to a system time value.
Hairong Shang
2004-01-16
